03-31-2022 07:14 AM
After getting the licensing applied to my Cat 9200 switch the log is constantly receiving the following message
lic_slm_event_notification: Received global event notification 16386
Does anyone know what causes this and how to resolve it.
03-31-2022 07:39 AM
Can you post show version, show License status
03-31-2022 10:52 AM
WH01-A92K-1#sho ver
Cisco IOS XE Software, Version 17.03.04
Cisco IOS Software [Amsterdam], Catalyst L3 Switch Software (CAT9K_LITE_IOSXE), Version 17.3.4, RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2021 by Cisco Systems, Inc.
Compiled Fri 02-Jul-21 19:32 by mcpre
Cisco IOS-XE software, Copyright (c) 2005-2021 by cisco Systems, Inc.
All rights reserved. Certain components of Cisco IOS-XE software are
licensed under the GNU General Public License ("GPL") Version 2.0. The
software code licensed under GPL Version 2.0 is free software that comes
with ABSOLUTELY NO WARRANTY. You can redistribute and/or modify such
GPL code under the terms of GPL Version 2.0. For more details, see the
documentation or "License Notice" file accompanying the IOS-XE software,
or the applicable URL provided on the flyer accompanying the IOS-XE
software.
ROM: IOS-XE ROMMON
BOOTLDR: System Bootstrap, Version 17.5.1r [FC4], RELEASE SOFTWARE (P)
WH01-A92K-1 uptime is 1 week, 2 hours, 58 minutes
Uptime for this control processor is 1 week, 3 hours, 0 minutes
System returned to ROM by Power Failure or Unknown
System image file is "flash:packages.conf"
Last reload reason: Power Failure or Unknown
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Technology Package License Information:
Technology-package Technology-package
Current Type Next reboot
network-essentials Smart License network-essentials
dna-essentials Subscription Smart License dna-essentials
Smart Licensing Status: Registration Not Applicable/Not Applicable
cisco C9200-48P (ARM64) processor with 651451K/3071K bytes of memory.
Processor board ID JAE25440RN7
13 Virtual Ethernet interfaces
52 Gigabit Ethernet interfaces
4 Ten Gigabit Ethernet interfaces
2048K bytes of non-volatile configuration memory.
4028872K bytes of physical memory.
819200K bytes of Crash Files at crashinfo:.
1941504K bytes of Flash at flash:.
Base Ethernet MAC Address : e0:69:ba:5d:a4:80
Motherboard Assembly Number : 73-20259-03
Motherboard Serial Number : JAE25440RN7
Model Revision Number : C0
Motherboard Revision Number : A0
Model Number : C9200-48P
System Serial Number : JAE25440RN7
CLEI Code Number : INM9200ERB
Switch Ports Model SW Version SW Image Mode
* 1 56 C9200-48P 17.03.04 CAT9K_LITE_IOSXE INSTALL
Configuration register is 0x102
WH01-A92K-1#sho license status
Utility:
Status: DISABLED
Smart Licensing Using Policy:
Status: ENABLED
Data Privacy:
Sending Hostname: yes
Callhome hostname privacy: DISABLED
Smart Licensing hostname privacy: DISABLED
Version privacy: DISABLED
Transport:
Type: Smart
URL: https://smartreceiver.cisco.com/licservice/license
Proxy:
Not Configured
Policy:
Policy in use: Merged from multiple sources.
Reporting ACK required: yes (CISCO default)
Unenforced/Non-Export Perpetual Attributes:
First report requirement (days): 365 (CISCO default)
Reporting frequency (days): 0 (CISCO default)
Report on change (days): 90 (CISCO default)
Unenforced/Non-Export Subscription Attributes:
First report requirement (days): 90 (CISCO default)
Reporting frequency (days): 90 (CISCO default)
Enforced (Perpetual/Subscription) License Attributes:
First report requirement (days): 0 (CISCO default)
Report on change (days): 0 (CISCO default)
Export (Perpetual/Subscription) License Attributes:
Miscellaneous:
Custom Id: <empty>
Usage Reporting:
Last ACK received: Mar 30 16:48:04 2022 CDT
Next ACK deadline: Jun 28 16:48:04 2022 CDT
Reporting push interval: 30 days
Next ACK push check: Mar 31 12:52:17 2022 CDT
Next report push: Apr 29 16:43:04 2022 CDT
Last report push: Mar 30 16:43:04 2022 CDT
Last report file write: <none>
Trust Code Installed: Mar 30 16:42:48 2022 CDT
01-21-2025 03:19 AM
hello
I see no more reply to this tchat
what is the way not to have any more those messages ?
01-21-2025 05:44 AM
I don't remember what fixed it. I think I had to open a TAC case with Cisco and it was resolved with them. Sorry cannot help more.
