After updating to CSPC 2.7.1, I'm now getting "The tail-end gateway is not registered yet" error for exporting
clark_collins
After the update CSPC 2.7.1 came out, I applied the update.  Then I noticed that I was getting the "The tail-end gateway is not registered yet" error when I export or upload the inventory.  I'm now on CSPC 2.7.2.5.  I re-exported my entitlement with no success.  I looked in the "Upload Processing" status and noticed many in "In Processing" state.
Any suggestions?  I have not gotten a success on upload after Aug 27th of 2017, just after I updated to CSPC 2.7.1.
Thank you,
Clark Collins IV
HI Clark,
I am glad to know that issue is resolved. When get chance, please mark post helpful to close conversation on given thread.
Supriya
16 Replies 16
Supriya Patel
Hi Clark,
You mentioned that I'm now on CSPC 2.7.2.5.  I re-exported my entitlement with no success.
1) what error are you receiving? Please supply us with screenshot of error?
2) Have you tried generating new certificate and uploading new certificate to collector?
3) Please private message me with company name, inventory and appliance id.
Supriya
Hello Supriya,
I have attached the screenshot of the error.
I'm not sure about the certificate.  I have not generated or uploaded any new one.
I will do.
Thank you.
Clark Collins IV
Hi Clark,
Under 'upload processing' tab on SNTC portal, I am seeing only system replayed that was due to SNTC4.0 migration. If you can get be below logs that will help to investigate further on why uploads are failing:
Please private message me below:
Using admin CLI login:
show version -d
From root, run below command:
cat /etc/hosts
cat /etc/sysconfig/network
wget https://72.163.7.113/HeadEndWebAppServlet/ --no-check-certificate
 Please grab below from root as well:
/opt/ConcsoTgw/tail-end-gateway-decoupled/bin/nohup.out
/opt/ConcsoTgw/tail-end-gateway-decoupled/bin/CONN_TEG_LOGS/tail-end-gateway.log
Supriya
Sorry for my delay, I was heading home for the day.
I have attached the log file of the output you requested.
Thank you,
Clark Collins IV
I forgot the the show version command:
admin# show version -d
        Build-name   : Collection Platform Software 2.7.2.5
        Package-type : ServicePack
        Version      : sp-30.0.2-5-0-lnx64
             Component : CSPC Base
             Version   : 2.7.2.5
        Package-type : JeOS
        Version      : jeos-30.0.2-5-lnx64
             Component : ConcsoTgw
             Version   : 1.6.8
             Component : AdminShell
             Version   : 1.5
             Component : Hardened CentOS
             Version   : 6.8 patch#0
             Component : CASP
             Version   : 2.7.2.5
             Component : LCM
             Version   : 1.5
Thank you,
Clark Collins IV
Hi Clark,
Could you please send me file permission for below:
/opt/ConcsoTgw/tail-end-gateway-decoupled/conf/csof_config.xml
Supriya
[root@hou-sntc01 ~]# /opt/ConcsoTgw/tail-end-gateway-decoupled/conf/csof_config.xml
-bash: /opt/ConcsoTgw/tail-end-gateway-decoupled/conf/csof_config.xml: No such file or directory
Hi Clark,
Please ignore my previous request since you are on 2.7.2.5.
Supriya
Hi Clark,
As requested in private message, please re-generate and reapply certificate and update us with result.
Supriya
I send it via PM.
Thank you,
Clark Collins IV
Hi Clark,
Thanks for sending requested information. I am investigating on the lab and update you.
Supriya
Hi Clark,
Sorry, it have been a while that i updated post. So far, I do not have success of replicating issue in the lab but I am still working on it. I will update you further when I have progress on this.
Supriya
Hi Clark,
As discussed in private message, please try loading your old certificate and let me know how it goes.
Supriya
HI Clark,
Supriya
