After Upgrade to 2.7.4 Software Upgrade Web UI errors
artbalkjr
Tried to upgrade to 2.7.4 from 2.7.3 via Web UI.  Web UI report applied failed.  Went to CLI and applied upgrade, upgrade completed and was successful, now running 2.7.4 but when accessing the software updates page in the Web UI get the following errors from the three pages:
Unable to get data from server for report: register
Unable to get data from server for report: available_updates
Unable to get data from server for report: settings
Any suggestions on how to correct these errors.
Supriya Patel
Hi User,
Please provide below for further investigation.
Show version –d command from admin
Please attach below from root
  1. /opt/LCM/logs/apply
  2. /opt/LCM/logs/install
  3. /opt/cisco/ss/adminshell/applications/CSPC/webui/tomcat/logs/catalina.out
Supriya
I have experienced the same behavior , was there a solution ?
Hello There,
Can you please see if the error still occurs after clearing your cache and reloading the software UI tab?
Thank You,
Jarrett
