Alert on portal SNTC version CSCP
Hi:
I upgrade CSCP to version version 2.8.0.1, but each time enter at SNTC portal, appear the attach alert. That is okay? or how to remove this alert?
thanks.
Best Regards.
Hi:
Thnaks for your answer fast, this is output command:
antchris
Hello Rafael,
Kindly share the following - login to the CSPC via SSH (CLI) and send me a screenshot..
login as 'admin'
run - #show version -d (sh ver -d)
You should see a similar printed output..
admin# sh ver -d
        Build-name   : Collection Platform Software 2.8.0.1
        Package-type : ServicePack
        Version      : sp-30.1.0-1-0-lnx64
             Component : CSPC Base
             Version   : 2.8.0.1
        Package-type : JeOS
        Version      : jeos-30.1.0-1-lnx64
             Component : AdminShell
             Version   : 1.8.1
             Component : LCM
             Version   : 1.8.1
             Component : CASP
             Version   : 2.8.0.1
             Component : ConcsoTgw
             Version   : 1.7.3
             Component : Hardened CentOS
             Version   : 6.10 patch#0
If the version displayed in the printed output differs, then it is possible that the upgrade did not complete/finish. However, if the version in the printed output does reflect this version, then I will do some additional investigation.
-AC
Hi:
