Can't retrieve token for app - EoX support API
mgrigs
I had an app that was using the EoX support API, and it stopped working at some point.  When I logged into the console, the APIs that it was subscribed to were labeled as "Deprecated."  I deleted the app and recreated it as grant type "Client credentials" and included the non-deprecated API (the same settings I had previously).  However, I am unable to access the EoX API--when I try to retrieve a token via https://cloudsso.cisco.com/as/token.oauth2, I get "Invalid client or client credentials."  Am I missing something?
mgrigs
This is now working for me - after I updated my URLs, Vivek synced something on the backend and that did the trick.
6 Replies 6
vivekcha@cisco.com
Could you please share the company name and User's CCO id in Private Message so that we can check further.
Thanks and Regards,
Vivek Chauhan
mgrigs
@karsten I updated my URLs, but I get a 403 forbidden now.
vivekcha@cisco.com I have sent you my info.
karsten
I checked and I have the same problem.
Hopefully Vivek can help.
Hi Karsten,
Thanks and Regards,
Vivek
mgrigs
