09-13-2017 07:24 AM - edited 03-12-2019 07:29 AM
I am having issue with being locked out of the SSH CLI for both the root and collectorlogin accounts. I can get in over the admin account. In other posts it says that the lockout is time based at 30 minutes. I have found that to not be the case. I have waited hours between attempts and hours later the lockout due to X failed attempts increments by the attempt I am making. I had some success previously getting the admin account unlocked by having the VMware admin get in directly to the console, it seems that a successful console login cleared the failed login counter. Is there any way via the CLI admin account to reset the lockout counter for the other accounts?
Solved! Go to Solution.
09-13-2017 09:06 AM
Hi User,
There is way to reset root and collectorlogin via CLI admin.
admin# pwdreset collectorlogin 90
admin# pwdreset root 90
Please do let me know if further assistance is needed
Supriya
09-13-2017 09:06 AM
Hi User,
Supriya
09-13-2017 09:20 AM
I tried this command and found that it did reset the password, but it did not reset the lockout counter
09-13-2017 04:55 PM
Hi User,
Once you reset via user 'admin' CLI login, please wait for about an hr (to be safe) and try login with new reset password for root and collectorlogin.
Supriya
09-13-2017 10:37 PM
Hi Supriya,
Is there a password recovery for the CLI? Our customer change the login and forget the login credentials. Now we can't access the CLI due to login credentials. Thanks.
09-14-2017 07:13 AM
