10-26-2018 07:28 AM
On any of the newer products, customer is getting a failed return due to not having the right platform definitions. I see that we can either add them from a zip… is there anywhere to download a collection of updated definitions? Or does each device need to be added manually?
10-26-2018 07:56 AM
Not sure what a failed return would be. If CSPC doesn't know about a platform, it still collects the default MIBs from it. You get support in CSPC for the newer Cisco products by upgrading to the latest version. CSPC 2.8 has the latest Cisco Product support.
10-26-2018 09:08 AM
Below is the response from the customer
"Everything is added to the include definitions except for exclude network and broadcast. This address is 10.X.XXX.X. I create a “custom” platform definition to include the Sys Object ID and it will work. However, I’d rather not have to do that manually for any new product. So far, I had to do it for our 3504 and our 9300’s. We’re running version 2.8, so we are updated."
10-26-2018 10:33 AM
10-26-2018 11:29 AM
The default SNTC collection profile is being used.
The two object IDs added were
3504 - 1.3.6.1.4.1.9.1.2427
9300 - 1.3.6.1.4.1.9.1.2494
10-26-2018 11:37 AM
11-02-2018 12:43 PM
11-06-2018 07:02 AM
12-18-2018 06:34 AM
I am currently running 2.8 with a rules package of 4.8. I am getting this error on 2960X and 3850 switches and 3925 and 819 routers. This is a new install.
12-18-2018 07:17 AM
I assume you are raising a separate issue from this thread. Can you please start a new thread with more details?
12-18-2018 07:22 AM
Its the same exact error as casey_biggs8. Only difference is hardware model and the fact that this is a new install. We had version 2.6, but due to upgrade issues, we just redeployed the 2.8 ova.
12-18-2018 07:38 AM
12-18-2018 11:44 AM
