Showing results forĀ
Search instead forĀ
Did you mean:Ā
CSAPI customer-details endpoint returns API_INTERNAL_004
nauto
I have successfully added the csapi-customer-1.0 API access via the API dashboard and can generate tokens. I know these tokens are valid, they work with all my other API requests. However, when I make CSAPI requests I get unexpected results. Any ideas what could be causing this? I don't think I'm making any errors with the request itself because I'm not having any problems with the Support EoX endpoints using the same token.
https://apix.cisco.com/cs/api/v1/customer-info/customer-details/
    "status": 400,
    "message": "System Error",
    "reason": {
        "errorCode": "API_INTERNAL_004",
        "errorInfo": "System is temporarily unable to process your request. Please try again later."
enrirami
Thank you for contacting Cisco.
I see you are facing this error "System is temporarily unable to process your request. Please try again later." but only when try to get information from csapi-customer-1.0 (Customer Info), but when you get information from Support EoX it works fine.
I would like to have more details regarding this query, can you please provide the following information?
CCOID:
Company Name:
Company Address:
You can send me the information via private message and I can check on our end.
Kind Regards,
Enrique Ramirez
CCO ID : ITSS.L2.Network-Security@internationalsos.com
Company: IinternationSOS
Addgress : singapore.
