CSP Collector Entitlement License File
Not applicable
How do I obtain this file?  I am trying to setup the Collector and TAC said I don't have the right contract and that I need it requires a NLS1, CSAS, or PSS contract.  Please advise!
Lynden Price
You are attempting to deploy CSPC 2.4, which is not compatible with the new portal. To enable the features of the SNTC portal, you currently have two options:
1) Wait until the release of CSPC 2.5, after which you will have access to a link to download the 2.5 OVA. Earlier versions require a TAC engineer to deploy and configure. The announcement of this release will be posted to the community.
2) Use the file import feature on the SNTC portal:
https://supportforums.cisco.com/document/12566046/csv-file-import-sntc-3x-application-note
You can access the portal itself by going here:
https://tools.cisco.com/smartservices/
Here is a link to the portal user guide that should go into more detail about the full list features you can use and reports you can generate:
https://supportforums.cisco.com/document/12566066/smart-net-total-care-portal-user-guide
Please let me know if you have any other questions.
Thank you,
Lynden
buenas tengo instalado la version del collector 2.5, me quede en la instalacion de la licencia tengo dos contratos asociados para el smarnet total care.. el problema es que no puedo continuar mi instalacion..
Muy buenas tardes
podremos por favor trabajar en tu duda en la comunidad en español? a través del siguiente link?
https://supportforums.cisco.com/es/community/12559196/smart-net-total-care-en-espanol
Gracias
