08-29-2022 06:11 AM
A GUI cspc sw upgrade 2.10.0.1 to 2.10.0.4 is failing. Could you please provide med the sequence of commands to fulfill a successfull upgrade via CLI?
admin# check update
Patch versions
Version Number: sp-30.3.0-4-0-lnx64
Description: Collector patch to upgrade CSPC 2.10.0.4
Required Versions: sp-30.3.0-0-0-lnx64
Optimal JeOS: jeos-30.3.0-4-lnx64
Reboot Needed: No
Restart Needed: No
Package Size: 456791518 bytes
Contents:
Component Name: Rules Pack
Version: 4.15
Description: 4.15
Component Name: CSPC Base
Version: 2.10.0.4
Description: CSPC 2.10.0.4
Installable: Yes
admin# show version -d
Build-name : Collection Platform Software 2.10.0.1
Package-type : ServicePack
Version : sp-30.3.0-1-0-lnx64
Component : CSPC Base
Version : 2.10.0.1
Package-type : JeOS
Version : jeos-30.3.0-1-lnx64
Component : AdminShell
Version : 1.9.5
Component : LCM
Version : 1.9.5
Component : CASP
Version : 2.10.0.1
Component : ConcsoTgw
Version : 1.8.1
Component : Hardened CentOS
Version : 7.9 patch#2009
Solved! Go to Solution.
08-29-2022 12:39 PM
Hi danielbarri,
Yes, there are two ways of accomplish the upgrade through (Admin shell and Transfer method).
The steps you shared is upgrade using Admin Shell.
Yes, the above steps mentioned by you accomplish the whole upgrade.
You do not need to download collector_2.10.0.4_Build-04.zip in case of upgrade using Admin Shell. You only need in case of Transfer method.
Please let us know if you face any issue.
Thanks & Regards,
Vivek Chauhan
08-29-2022 06:39 AM
Hi danielbarri,
Hope you are doing well!
We have shared details in Personal Message to upgrade the cspc through cli, you can check it once from your end.
Thanks & Regards,
Vivek Chauhan
08-29-2022 07:19 AM
Hi Vivek,
Thanks for your response! I've checked it and it seems there are two ways of accomplish the upgrade in my case, if I understood it correctly.
According the CSPC-Upgrade-guide, my upgrade path is:
2.10.0.1>JeOS 2.10.0.4 > SP 2.10.0.4> 2.10.0.4
I'm wondering if the Upgrade Using Admin Shell and the steps:
Step 4 To download the patch execute the command.
#download sp-30.3.0-0-0-lnx64
Step 5 To check download status execute the command.
#show download
Step 6 Once the download completes you can use the apply command to apply the patch.
#apply sp-30.3.0-0-0-lnx64
Step 7 To check the apply status run:
#show apply
Will above steps accomplish the whole upgrade?
Since the note states:
• LCM has the intelligence of automatically downloading and applying dependent patches
Example: jeos-30.0.4-0-lnx64.
So no need of downloading collector_2.10.0.4_Build-04.zip and Apply JeOS Package 2.10.0.4?
Or do I have to go for downloading collector_2.10.0.4_Build-04.zip and Apply JeOS Package 2.10.0.4, indeed?
08-29-2022 12:39 PM
Hi danielbarri,
Thanks & Regards,
Vivek Chauhan
08-30-2022 04:35 AM
For CSPC 2.10.0.1 upgrade to 2.10.0.3 via admin shell, the correct SP:
admin# check update
admin# download sp-30.3.0-4-0-lnx64
admin# apply sp-30.3.0-4-0-lnx64
