CSPC 2.10 configure a proxy with ssl certificate
PierreC
We have a proxy with ssl interception in our company, would it be possible to set the proxy configuration with a ssl certicate ?
Hi Pierrec,
Appreciate your patience!
Further, we would like to inform you that, unfortunately we do not have a documentation for this, but we need to allow the traffic for the CSPC to be able to reach the backend.
We have to allow concsoweb-prd.cisco.com (72.163.7.113) over port 443 through the firewall for the data to be uploaded.
We will have to allow the firewall to not perform SSL interception on the CSPC to be able to send a successful upload.
Thanks & Regards
Aishwarya Bhatnagar
7 Replies 7
aibhatna
Hi Pierrec,
Good day to you!
We are looking into the issue you posted and will get back to you with an update on this.
Thanks & Regards
Aishwarya Bhatnagar
Hi Pierrec,
You can only setup proxy using the command "conf proxy" in the admin CLI shell.
#conf proxy
Thanks & Regards
Aishwarya Bhatnagar
Can i find in the documentation an information about the unsupported configuration for a proxy with ssl interception ?
i would need this information to request a security exception for the cspc appliance.
Hi Pierrec,
Let me check and get back to you on this.
Thanks & Regards
Aishwarya Bhatnagar
Hi Pierrec,
Thanks & Regards
Aishwarya Bhatnagar
PierreC
Thank you
Hi Pierrec,
You're most welcome! Glad to help you.
Thanks & Regards
Aishwarya Bhatnagar
