CSPC 2.10 localhost login
miralpatel91
What is login for CSPC 2.10 ? I have just installed ISO file and asking  localhost login...None of the cisco default password  works
aibhatna
HI miralpatel91.
Hope you are doing good! We are looking into the issue you posted and will get back to you with an update on this.
Please share the screenshot of the error you are receiving in PM for further assistance.
Thanks & Regards
Aishwarya Bhatnagar
miralpatel91
This is the screenshot if that helps...
HI miralpatel91,
Thanks for sharing the screenshot. I have shared some details in Personal message. Please follow the same.
Thanks & Regards
Aishwarya Bhatnagar
Hi miralpatel91,
As discussed in PM , the  localhost is not taking any password so we requested to re-deploy 2.10 and set the new password again for the admin.
Sharing the installation guide for deploying 2.10 :
https://www.cisco.com/c/dam/en/us/support/docs/cloud-systems-management/common-services-platform-collector-cspc/CSPC-Installation-Guide.pdf
Thanks & Regards
Aishwarya Bhatnagar
