CSPC 2.7.4 Post Upgrade Connection to Platform Software Updates Server Fails
michael.taylor
Fellow Networkers,
Having CLI applied CSPC v2.74:
admin# show apply
Version Number : sp-30.0.4-0-0-lnx64
Status : Applied
Start Time : May/01/2018 12:26:15
End Time : May/01/2018 12:37:32
admin# sho version
Build-name : Collection Platform Software 2.7.4
Version : sp-30.0.4-0-0-lnx64
I get the following popup: Error: Unable to get data from server for report:register when trying to Connect to the collection server.
A similar popup appears when I select Get collection platform software updates.  This time the popup states: Error: Unable to get data from server for report: available_updates.
Setting to the reoccurring schedule is also out of the question.
Interestingly, I can reinitialise my CCO credentials from the CLI:
admin# conf server disable
This operation will disable connection with server for Software Updates.
Would you like to continue (y|n)? y
Operation succeeded.
admin# conf server enable
This operation will enable connection with server for Software Updates.
CCO Id : Frustrated.Engineer
Password :
Advice and Guidance would be gratefully received.
Thank you in anticipation.
Justin Sprake
Hi Michael,
Could you attempt to clear your webbrowser's cache or attempt to access the Web UI via a separate browser?
Justin Sprake
Hi Michael,
Hi Justin,
School boy omission; should have tried an alternative browser first.  Chrome is good.
Thank you very much.
Michael
