CSPC 2.7 stopped uploading
A.Begessinova
Good day,
Please advise,  CSPC 2.7 stopped to uploading data, it shows error:
Upload failed at 01/16/2019 09 18 46 AQTT with the response
A connectivity exception occured while processing the request. The Exception is HTTPs TransportMode has Failed 407 Proxy Authentication Required
_SNTC_1547612248316 603 1
Previously it works  without any problems... no additional configurations was made on our proxy.
18 Replies 18
I have done snmp test as advised by you, but it shows error:
[root@ncatsncv01 collectorlogin]# snmpwalk -v 2c -c r.....a((.. 10.x.x.x
bash: syntax error near unexpected token `('
But I configured <RO Community String> identically on network devices and CSPC..
Linux perceives certain characters as separate commands, you will need to comment those out with a \ while running the snmpwalk. I will update your private message with specifics to this issue.
I have sent to you snmp test results in private message. Could you please advise further action?
Thank you for confirming the SNMP RO community string configuration on the CSPC, discoveries are now taking place as expected.
