CSPC Administration Page
David Undernehr
Looking to configure MFA or block access via source IP to the administration web page of the CSPC. Anyone know if CSPC has an ACL/NAC feature to block by source IP?  it is possible to run fallwalld in the Guest OS to achieve desired request?
Thanks in advance!
David Undernehr
5 Replies 5
madhushr
Hi David,
This is to acknowledge you that your post is accepted by me and will assist you shortly
Thanks and Regards,
Madhusha R
David Undernehr
Sounds good Madhusha, looking forward to your assistance.
David Undernehr
Hi David,
Currently, MFA feature is not available to block access to the Web page of CSPC GUI. However, you can set up an SSL certificate for the collector.
Kindly let us know your inputs so that we can assist you accordingly.
Thanks and Regards,
Madhusha R
Thank you Madhusha for the assistance. You have been most helpful in ruling out our options. Unfortunately, SSL doesn't meet our needs for this particular issue but will keep it in mind.
Thanks again!
David Undernehr
Hi David,
Thanks for the update.
