CSPC Collector Boot Issues
fasteddye
Recently the CSPC 2.10 started spiking resources (cpu, memory, etc) and shutting itself down. After a few days it eventually it stopped booting. Reverted to a backup VM from week prior and system ran for several days ok and then started same symptoms as mentioned before. We had our VM Team spin up a fresh 2.10 OVA choosing medium deployment and that is not finishing the initial boot, it gets stuck during that initial boot process with the following message.
"A start job is running for /etc/rc.d/rc.local Compatibility (xxd xxh xxmin / no limit)"
Not sure if these are CSPC or VM issues?
Thanks.
neharani
I have acknowledged the post, and will get back to you shortly.
Neha Rani
neharani
Hi, Can you please share your availability to check this in real-time?
same has been asked in a personal message.
thankyou!
