CSPC Collector Deployment in Cloud
IOCNetwork1911
What are the options for deploying the CSPC collector in cloud? Is AVS supported?
I will appreciate any guidance on this.
Thank you,
The only official formats supported are vmwware - virtual (OVA) and UCS 220 M5 - hardware (ISO).
You can try deploying the ova on AVS but it is not officially supported.
Shreya Singh
6 Replies 6
shreysi3
I acknowledged your post. We will surely assist you on this.
Thanks and Regards,
Shreya Singh
Hi Shreya,
Just following up to see if you have any updates.
Thank you,
Augusto
Hi Augusto,
As we can see for cloud their is :
-Virtual Environment like VMWare and EXI
-ISO like CIMC hardware.
And for the AVS we will check with the backend and inform you as we get any response.
Shreya Singh
Hi Shreya,
Just following up about the deployment of CSPC in Azure VMware Solution.
Thank you,
Augusto
Shreya Singh
mmiles
It’s been over a year since this thread was last updated. Are there any new developments regarding cloud deployments or supported platforms for the SNTC CSPC collector?
Thank you,
Mike Miles
