06-27-2023 07:08 AM
What are the options for deploying the CSPC collector in cloud? Is AVS supported?
I will appreciate any guidance on this.
Thank you,
Solved! Go to Solution.
07-11-2023 06:09 AM
The only official formats supported are vmwware - virtual (OVA) and UCS 220 M5 - hardware (ISO).
You can try deploying the ova on AVS but it is not officially supported.
Shreya Singh
06-27-2023 08:06 AM
I acknowledged your post. We will surely assist you on this.
Thanks and Regards,
Shreya Singh
07-04-2023 06:13 AM
Hi Shreya,
Just following up to see if you have any updates.
Thank you,
Augusto
07-05-2023 06:35 AM
Hi Augusto,
As we can see for cloud their is :
-Virtual Environment like VMWare and EXI
-ISO like CIMC hardware.
And for the AVS we will check with the backend and inform you as we get any response.
Shreya Singh
07-10-2023 12:55 PM
Hi Shreya,
Just following up about the deployment of CSPC in Azure VMware Solution.
Thank you,
Augusto
07-11-2023 06:09 AM
Shreya Singh
12-11-2024 06:44 AM
It’s been over a year since this thread was last updated. Are there any new developments regarding cloud deployments or supported platforms for the SNTC CSPC collector?
Thank you,
Mike Miles
