CSPC collector - update sp-30.0.3-2-0-lnx64 - download failed
ccrfranck
I'm trying to update the collector.
Here is the error message:
admin# check update
Patch versions
Version Number: sp-30.0.3-2-0-lnx64
Description: Collector patch to upgrade to CSPC 2.7.3.2
Required Versions: sp-30.0.3-0-0-lnx64
Optimal JeOS: jeos-30.0.3-2-lnx64
Reboot Needed: Yes
Restart Needed: Yes
Package Size: 9158909 bytes
Contents:
Component Name: CSPC Base
Version: 2.7.3.2
Description: CSPC Base 2.7.3.2
Installable: Yes
admin# download sp-30.0.3-2-0-lnx64
execute % Error occured while executing command
I've tried many ways by adding several extensions and I've searched information about this issue but without success.
If someone has an idea...
Thanking you in advance.
Renaud
Hi Adias,
Thank you for your help. You're right, I made mistake applying commands. I've also added this "72.163.4.74 cloudsso.cisco.com" in my /etc/hosts file (even if I'm not using proxy).
Now it works.
Regards.
Renaud
9 Replies 9
Jarrett Pomeroy
Hello ccrfranck,
Can you please see if using the steps in the section "Enable Upgrades using LCM Software Updates" of the latest release notes helps to resolve your issue?  There are a few new additional host-names which we will need to add in order for the download to work.
2.7.3.2 Release Notes
Thank you,
Jarrett
I've followed step by step procedure with additionals host-names to add. Without results.
Regards.
Renaud
Hello ccrfranck ,
Can you please provide me the current version of your CSPC? You can find this by running the command "show ver -d".
Thank you,
Jarrett
Hello ccrfranck ,
Can you please also provide details if you are using a proxy or not on your setup?
Thank you,
Jarrett
Here is the show ver.
I don't use a proxy.
Thank you.
Renaud
admin# show ver -d
        Build-name   : Collection Platform Software 2.7.3
        Package-type : ServicePack
        Version      : sp-30.0.3-0-0-lnx64
             Component : CSPC Base
             Version   : 2.7.3
        Package-type : JeOS
        Version      : jeos-30.0.3-0-lnx64
             Component : AdminShell
             Version   : 1.6
             Component : LCM
             Version   : 1.6
             Component : CASP
             Version   : 2.7.3
             Component : ConcsoTgw
             Version   : 1.7.0
             Component : Hardened CentOS
             Version   : 6.8 patch#0
Hello ,
Can you please complete the commands under the section "Known Issue" on the Release Notes here?  Once completed, can you re-start your download command and see if it completes successfully on the new attempt.
Thank you,
Jarrett
I've already tried this but I've got this message:
[root@nrb0198av bin]# update updates set PACKAGE_STATUS = 'Apply-failed';
-bash: update: command not found
An idea?
Renaud
That above command is not a root command and you incorrectly applied it there. The command it is a derby database tool command and you would had to connect to it from a derby prompt once you apply the line commands that are delineated on the release notes document for 2.7.3.2 prior to issue the command. If successful you should had given you a prompt like ij>.
In any case prior to attempt that again send me the following below commands from root prompt and admin prompt
FROM ROOT USER
# tail -150  /opt/LCM/logs/install
and
# env | grep proxy
and
# ls -lart /opt/LCM/tmp/
and
# ls -lart /opt/LCM/tmp/downloads
FROM ADMIN USER
admin# show version -d
admin# show downloads
admin# show apply
Hi Adias,
Now it works.
Regards.
Renaud
