CSPC in Azure Cloud
sidris-sid
My client requires deploying CSPC; they already migrated all their servers to Azure.
The plan is to maintain the inventory of Cisco hardware for all their local/global offices.
Need to certify the following:
Can they deploy CSPC in Azure?
What are the bandwidth requirements? ---> is it better to consider the seed IP address of Core for discovery? Any savings for the bandwidth?
Is there any latency that needs to be considered between CSPC and discovered hardware?
Is it better to implement CSPC in one region vs. to implement multiple CSPC in different regions? -----> IT operation team currently operates from a central location/office for local/global offices.
keivbrow
Cisco does not support Azure deployments for the OVA, only VMWare on ESXi. Any alterations to the OVA file void Cisco support capabilities.
Thanks keivbrow, what if I built the CSPC on client Datacenter then i migrate the VM to Azure VM using one of the Azure migration tools. Does Cisco support it?
