10-18-2023 09:36 AM
I have a CSPC collector, version 2.9.x. It will not accept logins. When I try to login via HTTPS and enter in the admin ID and PW it shows "Connecting to CSPC server" and the cursor spins - and never stops spinning. When I try to log in via SSH and enter "collectorlogin" and the appropriate PW it says "Your account has expired; please contact your system administrator", which happens to be me. What do I do now?
10-18-2023 10:10 AM
I should add that I am able to log in as root from the VM console (I had to change my password, but I did so successfully).
10-18-2023 12:05 PM
This post is acknowledged by me, kindly share your availability for a WebEx meeting over a private message (PM).
Best Regards,
Tahereem Sayyed
11-07-2023 08:09 AM
Please contact me, I need a solution for this ASAP, I have multiple people whose projects are being held up by this.
10-19-2023 12:42 PM
I was able to log in as root via the VM console and then use "passwd <username>" to change the collectorlogin and admin passwords. But when I try to log in as admin through the GUI it just hangs regardless of what password I try and even when I use "Forgot Password?" on the login screen to change my password.
11-07-2023 09:13 AM
Hello Sir,
Thank you for contacting Cisco and Global CX - Smart Services Support Team.
We are investigating your request, I'll be with you in a moment.
Kindly regards.
Laura Olivera
11-07-2023 09:27 AM
Hello Sir,
Is this a physical device or a Virtual Environment?
Kindly regards.
Laura Olivera
11-07-2023 12:29 PM
11-08-2023 07:58 AM
Can I get some help on this please?
11-08-2023 11:40 AM
Hello RonF!
Thank you for that information! I just wanted to let you know that when you changed the CLI password (VM console password), the GUI password was not changed. Those are 2 different procedures.
On the other hand, the 2.9 version of the CSPC is now out of support. I recommend you upgrade your CSPC to 2.10, you can do so following this step by step:
The Manual upgrade consists of two packs as follows:
These are the steps to follow to make the Manual Upgrade:
Step 1. Login with CCO credentials and download the collector_2.10.0.6_Build-05.zip from the Download Center(Software Download - Cisco Systems) onto your local box.
Step 2. Copy the downloaded collector_2.10.0.6_Build-05.zip file to the collector appliance in thedirectory /opt.
Step 3. Login to collector appliance as collectorlogin.
Step 4. Switch to root using su – command.
Step 5. Run the cd /opt command as root.
Step 6. Unzip the downloaded collector_2.10.0.6_Build-05.zip file and ensure JeOS and SP are extracted using the ls command.
Step 7. Apply JeOS using the below command (installation runs in the background). Provide the confirmation when prompted. ./install.sh JeOS jeos-30.3.0-6-lnx64
Step 8. Monitor the installation by executing the following command: tail -f /opt/LCM/logs/apply After successfully applying the patch in /opt/LCM/logs/apply, the below logs are shown.
Note: Allocate 20-30 minutes for the installation to complete. The system will automatically reboot after installation.
Step 1. Login to collector appliance as collectorlogin.
Step 2. Switch to root using su – command.
Step 3. Run cd /opt command as root.
Step 4. Apply SP using the below command (installation runs in the background). Provide the confirmation when prompted.
./install.sh SP sp-30.3.0-6-0-lnx64
Step 5. Monitor the installation by executing the following command: tail -f /opt/LCM/logs/apply
After successfully applying the patch .in /opt/LCM/logs/apply, the below logs are shown.
Note:
Allocate 2-4 hours for the installation, depending on your network size. The algorithm runs only once to optimize storage and reduces the time required for future upgrades. The system will automatically reboot after installing the patch.
Make sure the collector 2.10.0.6 JeOS patch is installed successfully before proceeding further with Service Pack (SP) 2.10.0.6 installation.
Best Regards,
Laura Olivera
11-08-2023 12:32 PM
Is all that going to fix my problem?
11-08-2023 01:41 PM
It may help, and it is important to upgrade the collector since version 2.9 is out of support.
Best Regards,
Laura Olivera
