CSPC update, Apply-in-Progess hangs 30.1.0-1-0-lnx64
Lloyd KOLMAN
Critical Update 2.8.1.2 fails, Apply-in-progress, sp-30.1.1-2-0-lnx64 stuck, tried upgrade from 2.8.0.1.
admin#
show version -d
Build-name : Collection Platform Software 2.8.0.1
Package-type : ServicePack
Version : sp-30.1.0-1-0-lnx64
Component : CSPC Base
Version : 2.8.0.1
Package-type : JeOS
Version : jeos-30.1.1-2-lnx64
Component : AdminShell
Version : 1.9.1
Component : LCM
Version : 1.9.1
Component : CASP
Version : 2.8.1.2
Component : ConcsoTgw
Version : 1.7.5
Component : Hardened CentOS
Version : 6.10 patch#0
admin# check update
Patch versions
Version Number: sp-30.1.1-2-0-lnx64
Description: Collector patch to upgrade to CSPC 2.8.1.2
Required Versions: -
Optimal JeOS: jeos-30.1.1-2-lnx64
Reboot Needed: Yes
Restart Needed: Yes
Package Size: 1111718852 bytes
Contents:
Component Name: Rules Pack
Version: 4.9
Description: 4.9
Component Name: CSPC Base
Version: 2.8.1.2
Description: CSPC Base 2.8.1.2
Installable: Yes
admin# show apply
Version Number : sp-30.1.0-1-0-lnx64
Status : Applied
Start Time : Dec/04/2018 15:24:35
End Time : Dec/04/2018 16:16:02
Version Number : sp-30.1.1-2-0-lnx64
Status : Apply-in-progress
Start Time : Mar/25/2019 13:19:15
----Please wait for few mins for installation to complete......
Getting process exit code
WARN |
ERROR | PERROR: Error while installing the patch
Checking CSPC status..................TIMEOUT: Couldn't start CSPC. Please check the mysql service and port.
GUI- not available, "Unable to find valid certificate path"
Any help would be greatly appreciated.   Thanks in advance
2 Accepted Solutions
Bharath S
Hi Lloyd,
Need a small info on the statement  - GUI- not available, "Unable to find valid certificate path"
When did u encounter this ? Can you share screenshot if any ?
Also would be helpful if we can get /opt/LCM/logs/install and /opt/LCM/logs/apply  files.
Thanks & Regards,
Bharath S
Bharath,
Thank you very much for your fast response.
The Failure message happened when I tried to use the gui to update to 2.8.1.2
See attached log files.
Keep me posted
--lloyd
[cid:image002.jpg@01D4E930.01CCFBA0]
Bharath S
Hi Lloyd,
Thanks & Regards,
Bharath S
Bharath,
Keep me posted
--lloyd
