CSV file upload. No inventory displayed.
tstabor
I uploaded a small CSV file with just two devices, to see how this tool works and if it will be helpful to us. (we have hundreds of devices but I want to see this work with two first) After upload and logging out and back in, I don't see the new inventory. How long does it usually take?
asingadi
Hi Teed,
Thanks for reaching to us,Once your upload processed successfully  then you can see the data on the portal.
I have checked in the back end , there are two uploads been initiated and reached the SNTC server.We would suggest please do not push multiple uploads for the same company within a short period because unless the first upload gets processed completely, the second upload will never be completed .
Unfortunately we can not provide you the exact time for upload processing completion it depends on the load on the server.
Anusha.
