11-22-2021 06:21 AM
I upgraded from 2.9.1.1 to 2.9.1.2. Everything seemed fine. I went in via the GUI and verified the upgraded version. I then tried to run a collection. The web page hung. I closed the browser and reopened. The login dialog would not show. I got a blank screen. Decided to just reboot the device. ssh into CSPC as admin successful. Typed reboot and waited. Tried ssh again. Now I get the error "Adminshell service is not running. Please check the status using 'service adminshell status' command.". Then I get disconnected.
Looks like the Discovery is causing the problem. I ran a separate discovery from the scheduled discovery and it fails.
Solved! Go to Solution.
12-03-2021 05:57 AM
Since the base OS for 2.9.1.2 goes end of life this month, instead of continued troubleshooting, I decided to build a 2.10 server and recreate the settings.
11-22-2021 06:34 AM
Hi Charlie,
Hope you are doing well!
We are looking into the issue and get back to you with updates.
Vivek Chauhan
11-22-2021 12:10 PM
Hi Charlie,
Could you please let us know that have you upgraded the CSPC from CLI or GUI?
Please login as collectorlogin then go to root user in cspc cli:
To connect to root first connect to collectorlogin prompt and then issue the command su root as shown below
$ su root
a. Could you please run the following in CSPC cli
i. Run these commands in Root
ii. Run the following commands to restart the services:
iii. systemctl restart tomcat
iv. systemctl restart adminshell
v. systemctl restart cspc
vi. Then run to check the status:
vii. systemctl status tomcat
viii. systemctl status adminshell
ix. systemctl status cspc
b. Once you do the following please go back to the GUI then run the sntc collection profile again.
> It is recommended to clear cache before login to CSPC GUI
If you face any issue then please share the error.
Vivek Chauhan
11-23-2021 06:03 AM
Upgraded from CLI.
I restarted the 3 services, tomcat, adminshell and cspc.
Tomcat and adminshell returned to prompt.
After restarting cspc and returning to prompt:
[root@localhost collectorlogin]# [SSH] ERROR: Read from remote host 172.30.46.20: An existing connection was forcibly closed by the remote host. [SSH] FAIL: client_loop: send disconnect: An existing connection was forcibly closed by the remote host.
Logged back into CLI
[root@localhost collectorlogin]# systemctl status tomcat
— tomcat.service - SYSV: Tomcat Server basic start/shutdown script
Loaded: loaded (/etc/rc.d/init.d/tomcat; generated)
Active: active (exited) since Tue 2021-11-23 08:47:34 EST; 6min ago
Docs: man:systemd-sysv-generator(8)
Process: 65850 ExecStop=/etc/rc.d/init.d/tomcat stop (code=exited, status=1/FAILURE)
Process: 67494 ExecStart=/etc/rc.d/init.d/tomcat start (code=exited, status=0/SUCCESS)
Tasks: 0 (limit: 23637)
Memory: 0B
CGroup: /system.slice/tomcat.service
Nov 23 08:45:34 localhost systemd[1]: Starting SYSV: Tomcat Server basic start/shutdown script...
Nov 23 08:45:34 localhost su[67524]: (to casuser) root on none
Nov 23 08:45:34 localhost su[67524]: pam_unix(su-l:session): session opened for user casuser by (uid=0)
Nov 23 08:45:34 localhost tomcat[67494]: Starting Tomcat... su: warning: cannot change directory to /home/casuser: No s>
Nov 23 08:45:34 localhost tomcat[67494]: -sh: line 0: ulimit: max user processes: cannot modify limit: Operation not pe>
Nov 23 08:45:34 localhost tomcat[67494]: Tomcat started.
Nov 23 08:45:34 localhost su[67524]: pam_unix(su-l:session): session closed for user casuser
Nov 23 08:47:34 localhost tomcat[67494]: [ OK ]
Nov 23 08:47:34 localhost tomcat[67494]: chmod: cannot access '/opt/cisco/ss/adminshell/applications/CSPC/cspc_tomcat_s>
Nov 23 08:47:34 localhost systemd[1]: Started SYSV: Tomcat Server basic start/shutdown script.
[root@localhost collectorlogin]# systemctl status adminshell
— adminshell.service - SYSV: none
Loaded: loaded (/etc/rc.d/init.d/adminshell; generated)
Active: active (running) since Tue 2021-11-23 08:42:45 EST; 12min ago
Process: 65445 ExecStop=/etc/rc.d/init.d/adminshell stop (code=exited, status=0/SUCCESS)
Process: 65484 ExecStart=/etc/rc.d/init.d/adminshell start (code=exited, status=0/SUCCESS)
Tasks: 69 (limit: 23637)
Memory: 599.0M
CGroup: /system.slice/adminshell.service
”œ”€65552 /bin/sh /etc/rc.d/init.d/adminshell start
”œ”€65556 /bin/bash -c ulimit -S -c 0 >/dev/null 2>&1 ; /usr/bin/nohup /opt/cisco/ss/adminshell/derby/bin/star>
”œ”€65557 /opt/java/jre/bin/java -classpath /opt/cisco/ss/adminshell/derby/lib/derby.jar:/opt/cisco/ss/adminsh>
”œ”€65584 /bin/sh /etc/rc.d/init.d/adminshell start
”œ”€65588 /bin/bash -c ulimit -S -c 0 >/dev/null 2>&1 ; /usr/bin/nohup /opt/cisco/ss/adminshell/bin/shellserver
”œ”€65589 /bin/sh /opt/cisco/ss/adminshell/bin/shellserver
”””€65595 java -Djsse.enableSNIExtension=false -cp /opt/cisco/ss/adminshell/properties:/opt/cisco/ss/adminshel>
Nov 23 08:42:14 localhost adminshell[65484]: ]
Nov 23 08:42:24 localhost adminshell[65484]: Starting Derby DB: [ OKtput: No valu>
Nov 23 08:42:24 localhost adminshell[65484]: ]
Nov 23 08:42:25 localhost adminshell[65484]: Stopping Derby DB: [ OKtput: No valu>
Nov 23 08:42:25 localhost adminshell[65484]: ]
Nov 23 08:42:35 localhost adminshell[65484]: Starting Derby DB: [ OKtput: No valu>
Nov 23 08:42:35 localhost adminshell[65484]: ]
Nov 23 08:42:45 localhost adminshell[65484]: Starting Adminshell server: [ OKtput>
Nov 23 08:42:45 localhost adminshell[65484]: ]
Nov 23 08:42:45 localhost systemd[1]: Started SYSV: none.
[root@localhost collectorlogin]# systemctl status cspc
— cspc.service - SYSV: CSPC Start/Stop Script
Loaded: loaded (/etc/rc.d/init.d/cspc; generated)
Active: active (exited) since Tue 2021-11-23 08:47:35 EST; 8min ago
Process: 65791 ExecStop=/etc/rc.d/init.d/cspc stop (code=exited, status=0/SUCCESS)
Process: 66205 ExecStart=/etc/rc.d/init.d/cspc start (code=exited, status=0/SUCCESS)
Memory: 0B
CGroup: /system.slice/cspc.service
Nov 23 08:43:59 localhost su[66684]: pam_unix(su-l:session): session opened for user casuser by (uid=0)
Nov 23 08:43:59 localhost cspc[66205]: [89B blob data]
Nov 23 08:43:59 localhost su[66684]: pam_unix(su-l:session): session closed for user casuser
Nov 23 08:45:21 localhost cspc[66205]: [770B blob data]
Nov 23 08:45:33 localhost su[67441]: (to casuser) root on none
Nov 23 08:45:33 localhost su[67441]: pam_unix(su-l:session): session opened for user casuser by (uid=0)
Nov 23 08:45:33 localhost cspc[66205]: [267B blob data]
Nov 23 08:47:34 localhost cspc[66205]: Starting tomcat (via systemctl): [ OK ]
Nov 23 08:47:35 localhost cspc[66205]: [54B blob data]
Nov 23 08:47:35 localhost systemd[1]: Started SYSV: CSPC Start/Stop Script.
Cleared cache in browser prior to going into GUI.
Requires authentication twice. First time returns Invalid credentials even though i know it was typed correctly.
Clicked Collect Button to run collection profile. No response. Clicked again. No response. Canceled operation.
Clicked Job Run Status. Stuck on loading. No progress.
11-23-2021 09:06 AM
Hi Charlie,
Thank you for sharing the details. Please provide the below details in PM:
Company name:
CCO ID of user:
Vivek Chauhan
12-02-2021 11:37 AM
I see the same issues after upgrading to 2.9.1.2. The GUI dies after you request a discovery. I also had it die after trying to change a collection setting. My log files look similar to the ones provided by Charlie_Z.
12-03-2021 05:57 AM
