Error from Tail-end Gateway During Entitlement File Load
lukas.neuburger
During intital setup of the CSP Collectror v2.5.2.1 I receive a message during the installation of the entitlement file.
The message reads:
Entitlement update done locally, but failed on tail-end gateway. No response from connectivity tail-end gateway. CSPC not run without connectivity tail-end gateway.
I've attached a screen shot of the error as well.
Has anyone encountered this error? Any suggestions on resolving the issue.
Thank you,
-Lukas
10 Replies 10
Lynden Price
Hi Lukas,
Could you verify that you have access from the collector to the upload server?
Source IP Address Hostname Protocol Port Purpose
CSPC IP 72.163.7.113 Concsoweb-prd.cisco.com HTTPS 443 Upload to Cisco
CSPC IP
72.163.4.16
172.163.7.60
172.37.144.208
www.cisco.com
dl.cisco.com
sso.cisco.com
HTTPS/HTTPs 443/80 Patching
Lynden
I do have access from the collector to upload server (72.163.7.113):
I ran the command below as root on the collector:
# nc -v 72.163.7.113 443
Connection to 72.163.7.113 443 port [tcp/https] succeeded!
-Lukas
Hi Lukas,
What version of the CSPC are you running? Also, where did you get your entitlement?
Lynden
Lynden,
We're running v2.5.2.1, released in late October. I obtained the entitlment from the site listed below:
https://tools.cisco.com/smartservices/
-Lukas
Hi Lukas,
Did you generate your entitlement or download it? Are you using a proxy?
Also, what set of instructions are you following for setting up the collector?
Here's the guide I wrote: https://supportforums.cisco.com/blog/12696871/self-service-onboarding-setting-cspc-25-collector
I would actually recommend proceeding with the depoyment and seeing if your upload fails. Sometimes there are false messages about entitlement registration during the entitlement application process.
Lynden
Hi Lynden,
I generated the entitlment, then downloaded the resultant zip for installation into my Collector.
I am following the docutmentation provided by Cisco, I'll attach the two PDF files I referenced during the installation, and setup. I saw your guide when I first came to the forums, looks good but did not mention the error I saw.
I'll try to move forward with the setup process, to see if I can push data.
-Lukas
Hi Lukas,
That's the installation guide for the PSS collector. You want to deploy the SNTC collector. You can find a link to it in my blog guide.
Lynden
I completed a data collection and data upload run with the message show in the attached image. Does that look like a successful run? If so, how long before the data shows up in the portal?
Thank you,
-Lukas
Hi Lukas,
I see it in processing on our side. It can take 12-24 hours for it to complete, depending on how many uploads are ahead of you in the queue.
Lynden
Excellent, thank you.
-Lukas
