CSPC 2.4 upgrade to CSPC 2.5
jmichale
Is there a procedure for upgrading a customer that is running CSPC 2.4 to CSPC 2.5?
Could you please point me to the documentation.
5 Replies 5
Lynden Price
Hi, my name is Lynden Price with the SNTC Collector Support Team. Currently there is no patch to go from 2.4 to 2.5, so your only option would be to export your data from your 2.4 collector and deploy a new 2.5 collector. If you're interested in doing that, I can send instructions. Otherwise, the patch will eventually be available on LCM.
Thank you,
Lynden
Thanks Lynden!  Could you please send the instructions on how to export the data from the CSPC 2.4 collector and  import to the new CSPC 2.5 collector.
How to Migrate your Collector from 2.4 to 2.5
Log into your 2.4 collector:
  1. Reports > Managed Devices, select the blue export arrow. Export the managed device list in CSV format.
  2. Settings > Device Credentials, select the export button. Choose pari xml format.
  3. If you’ve set up local users or remote authentication, then make a note of those settings from Administration > Manage Users and Administration > Manage Remote Authentication Servers
In your case, if you have 2.4, then you probably have an NLS1 contract. You should open a TAC case and have an engineer help you get the new 2.5 server up.
Log into your 2.5 collector:
  1. Settings > Device Credentials, select “Import”. From the drop down, choose pari xml format. Browse to the exported credentials and select them. Give the job a name and click “OK”.
  2. Open the csv of your managed devices in Excel. Copy the column of IP addresses. In the collector, go to Management > Discover and Manage Devices. Select “Discover by known IP address”. Click “Next”. Paste the column of IP addresses into the entry box and then click the “Add” button. Click “Next”. Select the correct version of SNMP, and finish.
  3. Add any user accounts or remote authentication servers by going to Administration > Manage Users and Administration > Manage Remote Authentication Server
Please let me know if you have any questions.
Lynden
xinyezha
Hi Lynden
Very nice to meet you.
Can I ask you to send me some documents about how to install CSPC 2.4 on Windows.
You can reach me on Jabber/Email also.
Thank you  in advance.
Xinye
xinyezha@cisco.com
Hi Xinye,
We do not currently have a windows installer version of the CSPC. The latest version of the CSPC is 2.5, which comes as a VMware OVA.
You can get instructions on deploying it here: https://supportforums.cisco.com/blog/12696871/self-service-onboarding-setting-cspc-25-collector
Lynden
