File Import Error
Kerry Holland
My partner is getting an error when attempting a file upload using the provided CSV template from the portal. The error says "An error has been discovered in the format of the CSV file". He has redownload the CSV template and still receives the error when trying to upload. I have a screenshot and a copy of the CSV they used if someone wants to reach out to me directly to look.
Kerry
Pamela Ghosh
Hi Kerry ,
We are aware of this situation and we are working with engineering team already on priority for this issue , We will keep you posted with an update once the issue gets handle from our side .
Pamela
asingadi
Hi Kerry,
Hope you're good.
This issue is fixed , could you please try it now.
Thanks & Regards,
Anusha.
