Showing results forĀ
Search instead forĀ
Did you mean:Ā
How to check Smartnet warranty detail
worapolhitamata
I just buy and received my smartnet for my 6513 core switch with contract number. How I check if my vendor register it correctly by support period and all cover all module?
17 Replies 17
so I need to find a partner?
how to find a partner to update to update info?
Hello Linas,
You need to go back to the Partner you purchased the contract from. They will be able to help you.
In the case of the contract ending in '806' that is CDW LOGISTICS INC.
Regards, Tim
CDW is not a partner they just resell Cisco stuff
it took two weeks just to get access to SNTC
then I was listed as employee of CDW and CDW knows I am not an Employee and would not give me access??
ok ill try the CDW route
