Showing results forĀ
Search instead forĀ
Did you mean:Ā
How to get Smartnet coverage information via the Cisco API
tnakano03
I would like to get Smartnet coverage information via the Cisco API. I need to generate the API key using my client_id and client_secret. However, I don't know where to set up or register my client_id and client_secret. Can you direct me to the right direction?
https://apiconsole.cisco.com/apps/register
I tried to register ā€œapi.cisco.com/sn2infoā€ API but it is not listed here. I see only following APIs to register. How can I enable sn2ifo API?
  • CEEM API
  • Cisco On Demand CHIDS API
  • Cisco PSIRT openVuln API
  • Datafoundation-POE
  • HelloCommerce API
  • Workforce Mohit
===Python example
import requests
def get_access_token(client_id, client_secret):
url = "https://id.cisco.com/oauth2/default/v1/token"
headers = {
"Content-Type": "application/x-www-form-urlencoded"
body = {
"grant_type": "client_credentials",
"client_id": client_id,
"client_secret": client_secret
response = requests.post(url, headers=headers, data=body)
if response.status_code == 200:
token_info = response.json()
return token_info['access_token']
else:
return {"error": response.status_code, "message": response.text}
def check_smartnet_coverage(serial_number, api_key):
url = f"https://api.cisco.com/sn2info/v2/coverage/{serial_number}"
headers = {
"Authorization": f"Bearer {api_key}",
"Content-Type": "application/json"
response = requests.get(url, headers=headers)
coverage_info = response.json()
return coverage_info
else:
# Replace with your actual client_id and client_secret
CLIENT_ID = "your_client_id_here"
CLIENT_SECRET = "your_client_secret_here"
# Get the access token
access_token = get_access_token(CLIENT_ID, CLIENT_SECRET)
if "error" not in access_token:
# Replace with your actual serial number
SERIAL_NUMBER = "your_serial_number_here"
coverage_info = check_smartnet_coverage(SERIAL_NUMBER, access_token)
print(coverage_info)
else:
print(access_token)
There should be an option to select "Serial Number to Information API Version 2". It seems that you might be missing authorization to access this API. You can contact support at supportapis-help@cisco.com
Happy to help! Please mark as helpful/solution if applicable.
Get in touch: https://torbjorn.dev
5 Replies 5
Hi TorbjĆørn,
Thank you for your reply. Yes I sent email to supportapis-help@cisco.com as well.
enrirami
Thank you for contacting Cisco.
In this case, besides contacting API support team, you also need to confirm that you have the proper role to register and access APIs.
I would like to get more details about this, can you please provide the following information?
• Company name:
• Company address:
• CCOID of the one trying to access API:
• Email of the one trying to access API:
You can send me a private message if you prefer that way.
Kind Regards,
Enrique Ramirez
enrirami
Closing post due to inactivity.
Update:
I sent my API access request email to supportapis-help@cisco.com and I received the "Serial Number to Information API Version 2". access in my apps.
Thank you,
Toshi
