Inventory Operation Failed
Rajiv Dwaree
the inventory Operation is failing when we do a Run Collection profile. Could you please provide support?
2 Accepted Solutions
Agree with you and let´s close this one and stick to the previous one we are dealing with.
6 Replies 6
adias
Send me in Private the screenshot ( full top and bottom ) of your collection profile
and the following logs in private message
PLEASE TO DO THE FOLLOWING:
In deploying the  image  you would have created the cli admin password?  (java based shell)
If so have you also created/activated  the users collectorlogin and root ? (real linux shell)
If not do the following for the cli admin  shell
admin# pwdreset root 90
And
admin# pwdreset collectorlogin 90
it will activate those accounts and generate their passwords  ( keep them where you can refer to them in the future)
after that
Via SSH Login to collector as user collectorlogin and then use command below to connect as root (cannot connect directly)
# su root
and then the following commands :
# tail -100 /opt/ConcsoTgw/tail-end-gateway-decoupled/bin/CONN_TEG_LOGS/tail-end-gateway.log
# openssl s_client -showcerts -connect concsoweb-prd.cisco.com:443
# tail -100 /opt/ConcsoTgw/tail-end-gateway-decoupled/bin/nohup.out
# wget https://72.163.7.113/HeadEndWebAppServlet/ --no-check-certificate
hello Andre,
i already replied for a case that you are looking for the logs. once you replied back i will send you the logs and together the Collection profile ok
You can send the files on an email attached to the following alias sntc-support-community@cisco.com
on the title please put :   ANDRE LOGS for --> https://community.cisco.com/t5/notes/composepage/note-to-user-id/336683
Hello Andre,
I already sent the the logs of the inventory operation failed and internal server as both are the same client
