Login incorrect ISO installation over Hyper V Enviroment
AzgadIPNESIME
I have issue with first login on CSPC, I installed ISO CSPC over Hyper V, the default passwords (admin/Adm!n123) did not work, so I tried to re install the CSPC and I did all process again with the same result.
I attached the image of the error. Please cloud you help me with this issue.
adias
Present version from 2.7 to 2.8 do not have default passwords
passwords must be created at first login
I Installed the Collector-2.8.1.4-B-15.iso over my Hyper V enviroment, and after complete CentOs installation appears the message that I attached, so if there is no passwords by default why on the screen did request passwords?.
Thanks.
adias
that would only appear if there was a forceful skip on the password initial creation and or why asking to create the password it was not accepted . In essence try a new ISO install and verify if the step to create the initial password will appear as below.password.JPG
adias
reminding if you fail the required format too many times you will skip the process having that previously err
