03-30-2020 07:36 AM
Good morning team,
I have the following case of the account unicomer , customer have problems with licences every time we are going to update the collector however the customer told us that the licences is update , how we can proceed to solve the case, i will attached the main error that has the case.
03-30-2020 08:16 AM - edited 03-30-2020 10:44 AM
What is the present collection version. And please send the screenshot of the Collection profile ( top and bottom)
In deploying the image you would have created the cli admin password? (java based shell authentication is not the same as the GUI)
If so have you also created/activated the users collectorlogin and root ? (real linux shell)
If not do the following for the cli admin shell
admin# pwdreset root 90
And
admin# pwdreset collectorlogin 90
it will activate those accounts and generate their passwords ( keep them where you can refer to them in the future)
after that
Via SSH Login to collector as user collectorlogin and then use command below to connect as root (cannot connect directly)
# su root
and then send me by email the following commands outputs:
# df -k
# free
# service concsotgw restart
# service cspc restart
# tail -100 /opt/ConcsoTgw/tail-end-gateway-decoupled/bin/CONN_TEG_LOGS/tail-end-gateway.log
# openssl s_client -showcerts -connect concsoweb-prd.cisco.com:443
# tail -100 /opt/ConcsoTgw/tail-end-gateway-decoupled/bin/nohup.out
# wget https://72.163.7.113/HeadEndWebAppServlet/ --no-check-certificate
04-01-2020 07:56 AM
customer from the account unicomer reply the following information:
Hi Juan,
All the commands were successful except for the highlighted one below. Where the error is also in the logs attached.
Randall Howe
System Support Analyst, Regional IT - Unicomer (Trinidad) Limited
Tel (Office): +(868) 674 2122 Voip: 8 868 1095
Tel (Out of hours support): + (868) 681 9659
