Processing stuck
richwood
Since the upgrade, I have this stuck in my portal:
re-played_20171108T015317886+0000_9999002005695_CSP0009029433_CSPC
Been there since Nov 8th.
Can someone please take a look and either delete it, or fix it please?
Cheers,
Rick
taywelch
Hey Rick,
Can you send a new upload from the collector to make sure all is working as designed in the upgraded SNTC portal?
Taylor
New upload ran, but I have a lot of failed items, e.g.
FALLOUT REASON: Ciber Processor:No HardLine Record found, Ciber Processor:No Softline Record found, Mfg Processor:No record found in MFG
FALLOUT REASON: Ciber Processor:No HardLine Record found, Ciber Processor:No Softline Record found, Mfg Processor:MFG Pid not exist in ciber product master
FALLOUT REASON: Ciber Processor:Ciber Pid not exist in ciber product master, Ciber Processor:Ciber no softline record found, Mfg Processor:No record found in MFG
These are mostly for SFPs.
Is this is known issue?
Cheers,
Rick
Hey Rick,
This is normal behavior for the portal and the error message you are seeing simply means we cannot find the Part ID in our manufacturing database. Since these are only SFP's you would generally not cover these parts under a contract.
Taylor
