Registration Certificate
casey_biggs8
Have an issue with getting a "Failed” on the upload from the collector to services.cisco.com.  We have allowed an access control policy in the firewall allowing the servers listed for Cisco but still no luck. Have also tried applying a new certificate to the collector but we are getting a message that states "Registration certificate applied successfully locally but not applied to connectivity."
Below is the log pulled from 'cd /etc'
[root@ciscocollector etc]# cat hosts
127.0.0.1  localhost
127.0.0.1  localhost
::1  localhost
::1  localhost
72.163.9.100 nettools-upload.cisco.com
192.135.250.12 nettools-upload.cisco.com
64.103.36.134 nettools-upload.cisco.com
72.163.7.113 concsoweb-prd.cisco.com
173.38.37.173 concsoweb-stg.cisco.com
72.163.7.125 concsoweb2-prd.cisco.com
173.37.186.17 concsoweb-stg-old-vmmm.cisco.com
72.163.4.161 www1.cisco.com
72.163.7.38 upload.cisco.com
173.37.145.235 upload2.cisco.com
72.163.7.60 dl.cisco.com
72.163.7.60 dl1.cisco.com
173.37.146.12 dl2.cisco.com
72.163.4.70 sso.cisco.com
173.37.144.208 sso-prod2.cisco.com
adias
From the access to CLI using user collectorlogin and then user root send me in private the output from the following commands
# telnet 72.163.7.113 443
# wget https://72.163.7.113/HeadEndWebAppServlet/ --no-check-certificate
# openssl s_client -connect concsoweb-prd.cisco.com:443
# curl --tlsv1.2 https://concsoweb-prd.cisco.com/HeadEndWebAppServlet/ -v -k
# tail -100 /opt/ConcsoTgw/tail-end-gateway-decoupled/bin/nohup.out
# cat /etc/sysconfig/network
additionally from the CLI user admin send me the following
admin#  show version -d
