06-16-2016 12:35 PM
Is there a way to remove inventory from the Smart Net Total Care portal? I would like to remove (x2) inventory lists from the portal. Thank you in advance.
Solved! Go to Solution.
06-20-2016 03:09 PM
Hello Matthew,
There is no user-initiated way to remove inventories. If you have a valid NLS1 or CSAS contract, you can submit a TAC case to the portal team to request the deletion.
Nathalie
06-20-2016 03:09 PM
Hello Matthew,
Nathalie
