Serial Number to Description and Warranty API
smithron
Is there any APIs that we can use to look up information the description and warranty/Smartnet based on a serial number?
We are building our own inventory management system and I have serial numbers of the Cisco devices.
Screen scraping from http://tools.cisco.com/scc/ is not how we want to handle thousands of devices.
We would like to integrate our service with cisco.com directly to pull any information..
email is rsmith@rsmith.edu
20 Replies 20
Yes it still works, we use it every day.
Go to https://apiconsole.cisco.com/ and sign-in/register.  The API instructions are pretty good.  Just start with the Hello API to make sure your access token code works, then start integrating the other APIs.
Thanks a lot!
Sorry I'm a beginner on this, but if it doesn't appears in the options, does it mean that I can't use it? or can I add Serial number to information API with other method?
These are all the options that I have:
Yes there are quite a few more than that, including SN2INFOv2.  I don't know the rules around access levels to each API (e.g., are some partner only?).
I would send your CCO ID and access request to:
  1. ssapi-pilot-help@external.cisco.com and see if they can grant access, or
  2. http://www.cisco.com/assets/services/ts/smartnet/sch/smart_service_bureau.html, or
  3. Otherwise you may have to contact your Cisco rep and go from there.
Ok, thank you!
Jon Clark1
All I was looking for is this
https://cway.cisco.com/sncheck/
Geez guys come on.
