SNTC 2.5 - java.lang.NullPointerException error
Recently configured the Device Credentials for SNTC 2.5. I added a test network to be scanned and successfully ran a test discovery on that specific network. However, when I attempt to add/modify/remove any settings within SNTC I receive the Error: java.lang.NullPointerException. Has anyone encountered this issue? Any help is appreciated.
Lynden Price
Hi Christopher,
A reboot should fix this, since it's usually just an issue with the CSPC service. You can either reboot the VM, or log into the admin shell and run the command "sudo service cspc restart".
Lynden
