SNTC account setup process
markus_eling
Dears,
for weeks, the status of my newly created SNTC account is 'Account setup in progress' with the kind advice to check back later, account is available within 24 hours. As I wrote, for several weeks already. That's not what I call 'progress'. What's going on?
Thx,
Markus
Jarrett Pomeroy
Hello Markus,
I checked your account and found there was an error during the processing.  I have corrected your access and you should now be able to login to the SNTC Portal.  Please let me know if there are any questions.
Thank you,
Jarrett
7 Replies 7
Jarrett Pomeroy
Hello Markus,
Thank you,
Jarrett
I have the same symptoms. Although I've only been waiting over 24 hours, not several weeks. Mind taking a look Jarret?
Hello Josh,
Can you please check now and see?
Thank you,
Jarrett
All set, thanks!
I am also experiencing the same.  Appreciate your help.
Hi There,
Can you please try now and let me know?
Thank you,
Jarrett
Fantastic.  Thank you.
