Remove or Disable Captcha
cmmvwebmc
Is there a way to remove Captcha?  I thought this was for robot prevention.  I'm not sure that is an issue on our internal network.  It is more of a nuisance.
Jarrett Pomeroy
Hello Chris,
Unfortunately at this time there is no way to remove this security feature of the CSPC.  We are working with our development teams to see if this feature can be optional in future releases to make it easier to use.
Thank you,
Jarrett
Jarrett Pomeroy
Hello Chris,
Thank you,
Jarrett
Thank you.  That would be great if they could add that feature.  I would understand adding a 2fa option, but not captcha.
