04-26-2016 03:20 PM
Does there exist a vetted summary of "high" and "medium" criticality SNTC alerts ? ... On the Portal now, notice there are "Active Alert" summaries by TYPE --- PSIRT, Hardware EOX, Software EOX, and Field Notice. Can they be sorted by severity, or dates, first / last published, etc. ?
04-26-2016 03:45 PM
Hi John,
The answer is a partial yes.
In the portal, you can sort the data based on column(s). As you might imagine, you can sort in ascending/descending order. For example, for Hardware EOX (LDOS), you can sort based on the Last Date of Support column.
However, since you mention alert "criticality", we do not have such a field, hence you can't sort based on that value.
Bobby
04-27-2016 06:24 AM
Thanks Bobby,
Escalated to management.
John
