04-12-2017 01:32 PM
The bulk update option under Contracts/Not Covered is not working. It could be with all bulk updates, but this is the area where I need to change the status of for Modules and Power Supplies to No Coverage Required. After submitting the job for the bulk update, the Bulk Action Status immediately indicates that is has FAILED. This feature has worked in the past, but I have not used for several months.
Solved! Go to Solution.
04-21-2017 11:03 AM
04-13-2017 11:48 AM
Hi Nathan,
Please PM me (using below link) Customer name, Inventory name, CCOID and screenshot or error. I will take a look and update you further.
https://supportforums.cisco.com/blog/13237466/how-send-private-message-sntc-community
Supriya
04-18-2017 11:19 AM
Hi Nathan,
I received requested information and investigation is going on. I will update you further with findings.
Supriya
04-21-2017 11:03 AM
