SNTC file upload mismatch
piowil
First time I noticed serious mismatch after another csv file upload to SNTC. Many devices in my inventory has wrong PID types. For example one of C819G-4G-G-K9 was replaced to WS-C3750G-24TS-S. (why?...)
One line of imported csv file:
device-003432,10.10.23.104,FCZxxxxxxxx,C819G-4G-G-K9,00-00-00-00-00-00,branch-0787,IOS,15.5(3)M7
SNTC inventory shows as attached.
Piotr
9 Replies 9
sntcprodtest
Hi Piotr,
Please try below MAC format and let me know if it works?
Sample format --> aa:bb:cc:44:55:66
Supriya
Hi, I changed them to given format, did the upload again, but the same issue.
Piotr
As per private message, please attached the file that you are using to upload.
Supriya
Hi, please find my reply in priv message. Thank You.
I haven't received any file. Please send attachment using alias -
sntc-support-community@cisco.com
Supriya
Hi, mail just sent. Thanks!
Piotr
Thanks for sending. I am working on that right now and update you with my findings.
Supriya
I am still investigating on this. I will update you with detail on finding when I have.
Supriya
I have this same problem. Out of the 400 some odd devices I uploaded, the portal royally screwed up the product Id on about 100 of them.
And I'm not talking minor differences. It identified ASAs as 2960X. It even promoted an SG200 to a 3750.
I do see a pattern, though. It looks once it mistakes a device for, say a WS-C2960X-48TS-L, it keeps misidentifying devices as a WS-C2960X-48TS-L for a while until it switches to some other screw up.
