SNTC inventory file import not processing.
gsalas111
Upon losing upload data from the SNTC 4.0 upgrade, I'm trying to upload my original, along with new, data.
By all indications the CSV file imports succesfully, but it does not process or appear in Upload Processing.
The issue was resolved through private message.
The CSV File import was indeed processed successfully and inventory is available on the portal.
Gilbert needed to select the newly created inventory under Global Filter for Inventory and Segment selection.
Suchita Shewale
Dear User,
Would you be able to share the csv file that was used so that we can validate the data format?
You may send the file to community mailer: sntc-support-community@cisco.com
Suchita
On a second note I noticed there was one new inventory created today with CSV File import.
The devices also show up on portal under Custom Inventory Report.
At the moment, there are two inventories on your account.
Did you mean to say you created additional/third inventory via CSV file import and it does not show up?
Suchita
