SNTC page stuck in loop
vivarock12
Hola,
the client is having SNTC looping when they enter to the SNTC portal to generate the Token for the CSCP.
between this page and
what can be done in this case.
Saludos,
Gerardo Andree Mejía García.
Hello Vivarock12
If you are not using Mozilla Firefox, It will pop up Different errors including that one due to bug https://bst.cloudapps.cisco.com/bugsearch/bug/CSCwh61855.
please Give it a try in Mozilla Firefox, preferable in incognito window, and let me know.
kind regards.
10 Replies 10
wsmithtu
Hello Vivarock12.
Thank you for contacting Cisco.
In order to Verify what is happening, I will need the following information in a Private Message:
-Email/CCOID Affected: (if more than one, provide all of them)
-Company name:
-Company CR Party ID:
-Company Location: (Physical Address)
Once you share this information, Please allow me some time and I will contact you.
i send you the private message tell me if you need any more infomation.
Hello Vivarock12.
Thank you. I have received the information in Private message and I have escalated this internally to manually sync it, due to bug https://bst.cloudapps.cisco.com/bugsearch/bug/CSCwh03453 Wich is affecting the Automatic Sync.
As long as it get synced, I will let you know to verify it is Working fine.
were getting this problem now
could you help us with this new problem
Hello Vivarock12
kind regards.
helo now im getting an error when we generate the Entitlement for th Collector:
what can be done on for this to work.
now we were able to generated the entitlement (private firefox windows) file but not download the file.
thanks for the help by the way.
we try againg via firefox private page and it let us generate and download thanks for the help.
Ferenc Vissers
Hi @vivarock12 I also send you my info, because I seem to have the same issue.
I hope there will be a fix shortly.
Even FF in private mode no luck.
https://bst.cisco.com/bugsearch/bug/CSCwh61855
Weird thingy... It seems to work now... I am not sure why.
