SNTC Segment conditions not applied to Wireless APs
simonlane350
Hi everyone.
I've been using Segments in the SNTC portal to divide up our network inventory. The conditions that I've set in the portal are based on "host name begins with". It works fine for the wired devices, but not atall for the wireless AP's (of which I have about 3,000) in total. Is this by design, or a fault?
Thank you.
Suchita Shewale
Hello There,  Please send me customer and segment name along with segment criteria that you used as well as some example of Access Points that appear to have issue.
Suchita
