Software Updates server is down
John Palmason
Level 4
Level 4
I have tried your comands (posted in https://supportforums.cisco.com/t5/smart-net-total-care-portal-and/software-updates-server-is-down/m-p/3196141#M5547) and I am still geting the same error as the GUI. Do you have any other recomomdations?
Use '?' or 'help' to see supported commands.
admin# show version -d
        Build-name   : SNTC CSPC 2.6.1
        Package-type : ServicePack
        Version      : sp-2.0.5-0-0-lnx64
             Component : CSPC Base
             Version   : 2.6.1
             Component : Rules Pack
             Version   : 3.24
        Package-type : JeOS
        Version      : jeos-20.1.2-0-lnx64
             Component : ConcsoTgw
             Version   : 1.6.4
             Component : AdminShell
             Version   : 1.3
             Component : Hardened CentOS
             Version   : 6.8 patch#0
             Component : LCM
             Version   : 1.3
             Component : CASP
             Version   : 1.10
admin# conf serv enable
Server is down.
Please try again later.
admin# conf serv disable
Server is down.
admin#
Hello Supriya, I don't want to have to redeploy an new collector as it makes this difficult in the portal.   I already have two collectors in my portal  (one from older version and the current install) for history, adding nothing seems like the wrong response.
Is there no other troubleshooting steps to be taken?  I have been a long time SNTC user and have years of data on this collector.
JP
Supriya Patel
Hi John,
Looking at the information that you have provided, it seems the option that we have is to redeploy new collector.
Latest image, quick start guide and installation guide/steps is found on below link.
https://www.cisco.com/c/en/us/support/cloud-systems-management/common-services-platform-collector-cspc/tsd-products-support-series-home.html
Please do let me know if you have any further question on the same.
Supriya
JP
Hi John,
Sorry, it took time to response but at the same time I was checking if we can approach any other way. You have tried GUI as well LCM. Unfortunately, re-deploy option is left.
Supriya
