10-09-2017 11:55 AM - edited 03-12-2019 07:31 AM
I have tried your comands (posted in https://supportforums.cisco.com/t5/smart-net-total-care-portal-and/software-updates-server-is-down/m-p/3196141#M5547) and I am still geting the same error as the GUI. Do you have any other recomomdations?
Use '?' or 'help' to see supported commands.
admin# show version -d
Build-name : SNTC CSPC 2.6.1
Package-type : ServicePack
Version : sp-2.0.5-0-0-lnx64
Component : CSPC Base
Version : 2.6.1
Component : Rules Pack
Version : 3.24
Package-type : JeOS
Version : jeos-20.1.2-0-lnx64
Component : ConcsoTgw
Version : 1.6.4
Component : AdminShell
Version : 1.3
Component : Hardened CentOS
Version : 6.8 patch#0
Component : LCM
Version : 1.3
Component : CASP
Version : 1.10
admin# conf serv enable
Server is down.
Please try again later.
admin# conf serv disable
Server is down.
admin#
Solved! Go to Solution.
10-09-2017 05:02 PM
Hello Supriya, I don't want to have to redeploy an new collector as it makes this difficult in the portal. I already have two collectors in my portal (one from older version and the current install) for history, adding nothing seems like the wrong response.
Is there no other troubleshooting steps to be taken? I have been a long time SNTC user and have years of data on this collector.
JP
10-09-2017 12:57 PM
Hi John,
Looking at the information that you have provided, it seems the option that we have is to redeploy new collector.
Latest image, quick start guide and installation guide/steps is found on below link.
Please do let me know if you have any further question on the same.
Supriya
10-09-2017 05:02 PM
JP
10-13-2017 02:26 PM
Hi John,
Sorry, it took time to response but at the same time I was checking if we can approach any other way. You have tried GUI as well LCM. Unfortunately, re-deploy option is left.
Supriya
