Unable to Access SNTC portal
Hola,
Se me aprobó el acceso pero sigo recibiendo la página "Actualmente no tiene acceso a Smart Services Connection" cuando intento acceder.
Gracias,
adias
¿PUEDE PROBARLO AHORA SINCRONIFIQUÉ LA BASE DE DATOS DE AUTENTICACIÓN CON EL PORTAL SNTC
Hello Alexandre can you try now please?
I already worked thanks
however I have carried out the same procedure for another user of my
organization and also had the same problem you can validate if they
can also activate it
Please send me that user cco id in private message
