Smart Net Total Care Portal and Collector Discussions
The customer wants to buy BE7k with Drive Retention and it is the part "CON-UCSD7-BE7MM5K9". But I couldn't find any documents that provide detail about the scope/support. Any idea ? CON-UCSD7-BE7MM5K9 [UCS DR 24X7X4OS Cisco Business Edition 7000M (M...
Hi,I see that the discovery, collection and loading is being done correctly, however the complete information is not seen in the portal. It is not showing serials, alerts, hostname among others.The same is causing that the alerts are not seen updated...
We have deployed quite a few vEdge1000AC routers in the network.CSPC Collector (2.8)  located the devices, but unable to pull OS Version # and S/N. Is there a way to configure CSPC to pull OS and S/N for these devices? Thank you in advance for your h...
mchuarinc by Level 1
  • 863 Views
  • 3 replies
Hi Team,   I've requested access to some of my customer SNTC portals all which have been approved since Thursday 2nd April.  I currently only have access to one customer portal, but not the rest, can you please check this out and advise please?Thanks...
Hello allI have registered two contracts and eligible serial numbers to the smart net portal, but I will always be forwarded to the registration page. Also in the "Cisco Service Access Management tool" no roles are display as described in the "reques...
