Using SNTC portal for weeks, now message upon login says "Account Setup is In-Progress..." ???
D Kendz
Logged into SNTC Portal and was told that "Account setup is in progress-check back in 24 hours"  I have been using the portal for weeks.  I need to know why I have NO ACCESS to reports, inventory, etc.  Why is my account setup being completed again?  There are no "Notifications" in the portal of any errors, and no Community posts I have seen that can explain this screen.
6 Replies 6
npicard
Hi Daniel,
There was a sync issue earlier this week (Bug ID : CSCuw90441). I am checking with our back-end team if this could be the same issue affecting your access. Someone will update you via this thread as soon as possible.
Thanks!
Although I didn't see any update to the Bug, I have access restored as of this morning.  Thank you!
Hi Daniel,
Yes, our back-end team re-set your account. Thank you for confirming!
I have the same issue for over 5 days now.
Hi Michael,
I will request our back-end team review your account. I will keep you posted.
Nathalie
jdejager
I have this problem as well????
